T-350 lost forward gears. Reverse works - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2013, 08:28 PM
Last journal entry: more photos
i just had 1 do the same thing,was driveing and went to play around a little with son so stopped on pavement shot the gas to it it popped and made a weard sound so i got out and checked but seen nothing loose so turned around headed home. tranny was acting fine would drive fine for a bit then started acting like the rear drivers side brake had came loose and was sticking would lock up for a few sec so drove easy. tranny was acting fine till i got like 1 mile from home and just lost all forward gears, when in drive like transfer case was in nutral.but put in reverse and fine so has me baffeled tranny has less then 1500 miles on it and 2nd time ive had it do this and engine is a 350 bored 40 over with biggest cam i could get has a set 882s with the smaller truck heads.also has a set of 41;10 axles. im shure the engine isnt to big for the tranny but dont understand 2 trannys close to same problem about a yr ago its a 83 gmc 1500 4x4 just baffled y going out like this
Old 08-30-2013, 02:55 PM
well pulled pan yesterday amd found some scrap metal in pan so not looking good may have messed up direct drive gears in tranny not alot of clutch material in pan.will let u know more when i figure it out
Old 08-30-2013, 04:46 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I moved your posts from the olt thread. It is best to not post your problem in another members thread. It gets confusing.
As I posted in the other thread... IF your trans backs up(reverse works), this shows a few things.
Pump is working if trans backs up.
Converter is transfering power
Input shaft is connected to drum
Direct clutch is working for reverse
Low-reverse clutch is working for reverse
Have you tested forwards gear in ALL manual shifter positions?
The Following User Says Thank You to Crosley For This Useful Post:
mr_firewall (08-31-2013)
Old 08-31-2013, 09:43 PM
well thanks for the help and tested all gears shifted on tranny as well as shifter same
T-350 , no forward gears or reverse Zep40boy Transmission - Rearend 2 09-25-2012 10:49 AM
T-350 trans no forward gears work but reverse still works verndogg Transmission - Rearend 1 02-29-2012 04:51 PM
fresh rebuilt turbo 350 transmission hardly shifts into reverse and no forward gears 79malibuclassic Transmission - Rearend 3 04-10-2011 11:00 PM
350 lost forward gears - oil smell burned Jouba Transmission - Rearend 5 02-16-2009 11:05 PM
T-350 - no forward gears, only reverse.... 70chevyLVR Transmission - Rearend 7 01-21-2009 05:44 AM
