T-350 Low/Reverse clutch stack, 4 or 5? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2013, 03:51 PM
I am in the process of building up a TH-350 for a street car. I had the pistons machined for the direct and forward stack to accept 5 clutches. Would it really be a performance increase to having the low/reverse clutch piston machined to accept a 5 clutch stack? My understanding is, when you shift into manual low from a stand still, you will have the low/reverse roller holding and the low/reverse clutch applied and holding. So 1 extra clutch disk should not help much with holding in manual low, but cause more drag on 2nd and 3rd?
And so I don't have to make another thread, I have a question on front clutch stack clearances. B&M specs .015 - .030 (.015 seems too tight), another spec used .020 - .040, a MOTOR manual says .010 - .090 (pretty wide range). Any thoughts on clearances used that work well with good clutch engagment and little forward creep in neutral?
Old 02-21-2013, 09:49 PM
jakeshoe's Avatar
What application do you plan to use the trans for? Max RPM? What valve body?
The rule of thumb is .010" per friction and it's a pretty safe one but not always the absolute.
The larger diameter of the intermediate clutches necessitate a bit more clearance IMO. .015-.020" per friction is good.
A transbrake, offroad, or extremely high rpm combo may need a bit more clearance all around.
The forward clutches can be pretty tight, as they are not a shifting clutch. .020" total play will work but may creep in neutral. .070" will work fine too.
I set the directs at .050-.070" depending on clutch count and application.
I would just run 4 low/reverse frictions as long as it's not a transbrake application.
Old 02-22-2013, 11:12 AM
Street car with 425 hp, 6500 rpms, 3000 stall, b&m valve body mods (spring changes). I figured .020 on the forward clutch should be fine. I was more curious about the low/reverse clutch stack. Looking for confirmation that the low/reverse roller and clutch will be holding in manual low range. Thanks for the reply!
Old 02-24-2013, 07:54 PM
jakeshoe's Avatar
Yes L/R holds in manual low.
Old 02-25-2013, 08:23 AM
I looked at my automatic trans motor manual which had an operation power flow chart. This explains that the low/reverse roller is holding in auto drive and manual low. Shift in manual low, and now you have the low/reverse roller and the low/reverse clutch applied and holding. Conclusion is, 5 clutch stack over a 4 clutch stack should not provide that much, the possible drag on 2nd and 3rd in having a 5th clutch could be worse on the trans for my application.
4L60e Low Reverse Clutch abbazabba Transmission - Rearend 8 10-13-2012 10:38 AM
How do you get the right height dimesions for the low and reverse clutch stack up old yukon Transmission - Rearend 12 04-24-2011 11:07 PM
Which way does the low reverse roller clutch assembly go? old yukon Transmission - Rearend 6 04-22-2011 05:55 AM
4L60e low-reverse clutch retaining clip stuck! old yukon Transmission - Rearend 5 01-25-2011 10:39 AM
700r4 Low/Reverse Clutch Pack 123pugsy Transmission - Rearend 2 12-29-2007 08:31 AM
