Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 major leak
Old 10-26-2012, 10:14 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Used trans? Possible the converter hub seal is leaking because the pump bushing moved forward into the lip seal. i'd check all parts up front, there are mroe than 1 seal there.
Seals on bolts, O-ring and gasket on the pump
