Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 major leak
Old 10-27-2012, 08:35 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Originally Posted by Crosley View Post
Used trans? Possible the converter hub seal is leaking because the pump bushing moved forward into the lip seal. i'd check all parts up front, there are mroe than 1 seal there.
Seals on bolts, O-ring and gasket on the pump
Absolutely correct, when the trans is out, check all seals and for insurance it may be wise to replace all seals while it's apart.
