T-350 major leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2012, 04:58 PM
prettyboyced's Avatar
T-350 major leak
I have a th350 I bought used and was working great for the past couple of weeks but all of sudden it has a huge leak while running it doesn't leak while sitting or if I'm just turning the motor over
Old 10-26-2012, 07:52 PM
Faith - Respect - Trust
Is it leaking from the front or the back of the trans...it sounds like a seal leaking when under pressure. If it's the rear seal it's an easy fix...Front seal...more difficult but, the first step is to find out where the leak is.
Thanks
Ray
Old 10-26-2012, 08:26 PM
It's leaking from the front I had the car up in the air while it running and it's coming out from the front seal and if I pull the trans how will I figure out what is damage
Old 10-26-2012, 08:53 PM
Well the good news is that it's probably the front seal which means you need to pull the trans to be sure. The bad news is you got to pull the trans. Remove the converter and get a closer look.
Old 10-26-2012, 10:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Used trans? Possible the converter hub seal is leaking because the pump bushing moved forward into the lip seal. i'd check all parts up front, there are mroe than 1 seal there.
Seals on bolts, O-ring and gasket on the pump
Old 10-27-2012, 08:35 AM
Absolutely correct, when the trans is out, check all seals and for insurance it may be wise to replace all seals while it's apart.
Old 11-20-2012, 02:55 PM
After months I finally pulled the trans but really can't tell if it's the seal or not
Old 11-29-2012, 07:41 AM
It was the bushing in the pump
TH 350 leak shane.,herold Transmission - Rearend 3 04-13-2011 07:15 PM
Major leak at hose connection primalfear6 Transmission - Rearend 4 03-28-2009 03:46 PM
TH 350 leak ajd Transmission - Rearend 2 06-19-2007 07:50 AM
350 Leak Mertz Transmission - Rearend 8 07-14-2005 02:23 PM
Major transmission leak....HELP! TurboS10 Transmission - Rearend 12 05-07-2004 05:04 AM
