T-350 makes the engine stall in D not in R - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2012, 02:02 PM
Hi. Having trouble with a TH 350 in a Olds 442. Over a period the trans had trouble starting in "Drive". Now it only runs in "Reverse". When I shift to "Drive", the engine stalls. I can restart the engine in "Park", but the engine still goes out, when I shift into "Reverse". I have never had this problem with a transmission before. Any ideas?
Old 11-19-2012, 07:04 AM
Sorry, I got a word wrong. The engine only stops whwn I shift into " Drive " !!!
Old 11-21-2012, 02:13 AM
SSedan64's Avatar
Are you sure it's not a TH350C with Lockup TC/TorqueConverter? 350C has an electrical connection on driver side.
If so, possibly a Bad TCC/TorqueConverterClutch.
a company that makes engine adapters bigalow Engine 3 10-14-2011 12:34 PM
Engine makes a woosh noise, help. bigtread Engine 7 08-26-2011 03:33 PM
New T-350 rebuild makes grinding/scraping noise Dizturbed One Transmission - Rearend 5 05-08-2011 07:14 PM
Rebuilt 350 Olds makes clapping noise cutlass00 Engine 4 12-02-2009 04:42 PM
engine makes crackling sounds novadan Engine 7 04-15-2005 03:57 PM
