T-350 , no forward gears or reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2012, 02:19 PM
Hey guys, been searching all day and haven't found exactly what I need. I bought an 83 chev mud truck with a Th350 trans. Got er trailered, and had no forward gears, including manual gears. Actually, when I put it all the way down in one, it has a slight learch like it tried going into gear, but no movement. When I put it in reverse, my truck dies. When I'm able to keep it running in reverse, it feels like I'm trying to push against the e-brake. Fluid is fine, I've been searching and all I've round is no forward gears and reverse working fine. Haven't seen anything about all of it at once.
Could I have a plugged trans cooler line? Looks kindve shady. Would that do anything? Any help would be appreciated.
Old 09-24-2012, 06:43 PM
When you say the fluid is fine do you mean there's plenty of it or it looks clean? I have one and when I first tried to get it moving, I would put it in any gear and would only rev. I added a quart or two more fluid, and its good as gold. It really shocked me how just having not enough it will not move it at all. That's just my $.02 though.
Old 09-25-2012, 10:49 AM
vinniekq2's Avatar
smell the oil. pull the pan if oil has even a slight burnt smell.I doubt its a simple fix.
4L60E loses all gears forward and reverse. paul sullins Transmission - Rearend 4 07-28-2012 01:24 PM
T-350 trans no forward gears work but reverse still works verndogg Transmission - Rearend 1 02-29-2012 04:51 PM
fresh rebuilt turbo 350 transmission hardly shifts into reverse and no forward gears 79malibuclassic Transmission - Rearend 3 04-10-2011 11:00 PM
I have a 350T tranny with no forward gears but I have reverse mudking383 Transmission - Rearend 1 07-20-2009 07:34 PM
TH350 - no forward gears, only reverse.... 70chevyLVR Transmission - Rearend 7 01-21-2009 05:44 AM
