T-350 not shifting into second gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2012, 04:22 PM
hey im having problems with my th350 automatic transmission which is not shifting into 2nd gear. i had just recently dropped the pan and reconnected the s-link going to he linkage and forgot to clean the inside of the pan so i think it could be gummed up. ive also had a bad vacuam problem which causes me to be driving double-footed most of the time. i didnt know if this wouldve adversely affected the transmission, let me know if you have any solutions.
Old 09-09-2012, 04:44 PM
Check your modulator valve and lines. That may also be your source of the vacumn problem.
Old 09-09-2012, 04:47 PM
thanks for your reply. would that also be the source of the problem for the transmission?
Old 09-09-2012, 05:07 PM
Yes, the vacuum modulator is mounted on the transmission and has a rubber line going to it . This is what helps your transmission shift gears. If the modulator or line has a vacuum leak, your transmission won't shift gears. Hope this helps, Bill.
Old 09-09-2012, 05:11 PM
thank you very much bill ill get that checked out a.s.a.p and let you know how things go
4l60e shifting or second gear problems? kartorium Transmission - Rearend 9 11-23-2011 11:59 PM
700r4 not shifting out of 1st gear metalhead2910 Transmission - Rearend 1 08-09-2008 02:16 PM
shifting into first gear zipfactor Transmission - Rearend 7 01-10-2006 01:14 PM
700r4 shifting and 2nd gear . eliotmansfield Transmission - Rearend 4 06-20-2004 03:09 AM
700r4 not shifting out of 1st gear AKGMC Transmission - Rearend 2 06-08-2003 04:27 PM
