T-350 Part I.D. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2012, 01:27 PM
T-350 Part I.D.
In the picture below, what is this round disk called? The reason why I ask, I have been cleaning mine up and fixing the leaks. As I was scraping some gunk off the inside of this area, the whole thing move a little bit and allowed a tiny bit of fluid to start trickeling out. Theres no since in putting it back in if clearly it will leak from this area, but Im not sure what its called to get the right gasket/o-rings for it. Any help in the right direction is appreciated!
Old 10-04-2012, 03:27 PM
SSedan64's Avatar
1-2 or Intermediate Accumulator
https://www.wittrans.com/Schematic.a...0C&Schematic=4
prostreet6t9's Avatar
Differential/Driveline
Accumulator.
350 buick;tough starts, sputters at part throttle malibusimon Engine 5 03-21-2012 12:36 AM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 01:44 AM
i need a piston ring part number. 98 350 vortec 406 ss monte Engine 3 06-03-2006 11:22 PM
What is this part pgtr Engine 10 11-23-2004 12:12 PM
i need some part id help Lightspeed Hotrodders' Lounge 6 10-14-2002 08:52 PM
