Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 , press gas pedal, truck does not move forward instantly
Old 07-08-2012, 02:11 PM
mmerlinn mmerlinn is offline
Wiki Edits: 85
Does the fluid smell burnt? If so, your clutches are shot and you need a rebuild.
The most common cause of shift delay is too much slop in the clutches, normally meaning they need to be replaces. A worn out pump will cause the same symptoms as it takes time to build pressure to apply the clutches.
