-   -   T-350 , press gas pedal, truck does not move forward instantly (http://www.hotrodders.com/forum/t-350-press-gas-pedal-truck-does-not-move-forward-221428.html)
Chevyman87 07-08-2012 01:25 PM
I have a 350 turbo I put in my truck about a month ago, and I noticed that when I press the gas pedal, my truck dones not automatically move forward, there is about a 2 second delay before it actually goes forward. Best way to describe it is the transmission acts like its low on tranny fluid but I know it's not. Any suggestions?
mmerlinn 07-08-2012 02:11 PM
Does the fluid smell burnt? If so, your clutches are shot and you need a rebuild.
The most common cause of shift delay is too much slop in the clutches, normally meaning they need to be replaces. A worn out pump will cause the same symptoms as it takes time to build pressure to apply the clutches.
DanielC 07-09-2012 07:00 AM
First, check the fluid level.
S10 Racer 07-09-2012 05:54 PM
Also check the tranny filter. If it is restricted it may take a second or two to get fluid flowing.
Chevyman87 07-09-2012 11:19 PM
Thanks
I will try the 2 cheapest things first, fluid check and filter check. I also have a leaking weep hole which I sealed with RTV sealer at the advice of my uncle (30 years exp) do maybe that will help with fluid loss but no the fluid does not smell burnt just smells like tranny fluid .
Chevyman87 07-09-2012 11:22 PM
I also have a question
I read somewhere that packing some bearing grease in the yoke where the splines are also helps to stop fluid leaking from the weep hole. I was wondering if this is true and if so, is it safe?
S10 Racer 07-09-2012 11:55 PM
It should help and I don't see anything it would hurt.
