T-350 , press gas pedal, truck does not move forward instantly - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2012, 02:25 PM
I have a 350 turbo I put in my truck about a month ago, and I noticed that when I press the gas pedal, my truck dones not automatically move forward, there is about a 2 second delay before it actually goes forward. Best way to describe it is the transmission acts like its low on tranny fluid but I know it's not. Any suggestions?
Old 07-08-2012, 03:11 PM
Wiki Edits: 85
Does the fluid smell burnt? If so, your clutches are shot and you need a rebuild.
The most common cause of shift delay is too much slop in the clutches, normally meaning they need to be replaces. A worn out pump will cause the same symptoms as it takes time to build pressure to apply the clutches.
Old 07-09-2012, 08:00 AM
First, check the fluid level.
Old 07-09-2012, 06:54 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Also check the tranny filter. If it is restricted it may take a second or two to get fluid flowing.
Old 07-10-2012, 12:19 AM
Thanks
I will try the 2 cheapest things first, fluid check and filter check. I also have a leaking weep hole which I sealed with RTV sealer at the advice of my uncle (30 years exp) do maybe that will help with fluid loss but no the fluid does not smell burnt just smells like tranny fluid .
Old 07-10-2012, 12:22 AM
I also have a question
I read somewhere that packing some bearing grease in the yoke where the splines are also helps to stop fluid leaking from the weep hole. I was wondering if this is true and if so, is it safe?
Old 07-10-2012, 12:55 AM
S10 Racer's Avatar
It should help and I don't see anything it would hurt.
Relationship between Gas Pedal and Brake Pedal 35WINDOW General Rodding Tech 12 01-11-2012 02:35 PM
press the brake pedal and the engine sputters.??? 74chevyflat Engine 1 07-22-2006 08:23 AM
How to move forward with a 56 Chev Bel Air kansas Engine 5 05-14-2006 02:37 PM
gas pedal and linkage on 56 chevy 350 jackfrost51 Engine 3 04-25-2005 03:04 PM
move steering forward ???????? pozz33 Suspension - Brakes - Steering 2 11-14-2003 02:47 PM
