T-350 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2012, 10:43 AM
67MercCat's Avatar
Junkyard Dog
T-350 question
Hey guys! This is my first time dealing with a TH-350 and I'm getting ready to fire the engine up. I started pouring trans fluid into the trans and it started leaking from a hole with a wire sticking out of it just below the trans cooler lines. At first I thought it was the dipstick but it looks like some sort of pressure release valve or something. What is it? Should it be plugged?
Thanks
Old 08-13-2012, 01:01 PM
RWENUTS's Avatar
Got a pic!
Could be kickdown cable!
Old 08-13-2012, 03:21 PM
67MercCat's Avatar
Junkyard Dog
ill try and get down in there but it might not be possible to get a pic in that tight space. Its on the passenger side too. Maybe I'll have to drop the headers again
Old 08-17-2012, 08:44 PM
350 switch
its a oem timing retard switch for high gear you can remove and install a plug.
th 350 question cutthroatkid Transmission - Rearend 2 05-28-2012 06:19 PM
350 question morepower16 Engine 7 02-27-2007 06:53 PM
Please help!! 350 Question 66 chevy truck Engine 14 01-04-2007 10:02 PM
Th-350 Question T-bucket23 Transmission - Rearend 3 08-31-2005 11:06 AM
91-5.7 350 question Dan Augustine Engine 8 02-02-2002 06:32 AM
