T-350 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2013, 08:51 PM
T-350 question
I just started a full restoration on a 86 c10 I picked up. I pulled the trans out today cause I wanted to put a b&m shift trans kit in it. But I'm not sure if its a 350 or 350c. The one thing I did notice is there is a HD mark on the top of the case. Can anyone help or tell me what to look for.
Old 05-04-2013, 11:25 PM
pricesgarages's Avatar
probly a 375 witch is a th400 with a 350 style out put shaft so a turbo 400 shift kit will work
th 350 used till 1980 had rear modulator and cable down shift
th 350c 81-86 looks like a th350 but has a blue square plug on driver side
t 400 or 375 modulator on passenger side and kick down switch on driver side
Old 05-07-2013, 10:50 AM
The thm-350c was stock in those trucks. I had an 84 GMC Sierra with the 250cid 2 barrel straight 6 with the 350c.
It has the 4 prong square plug which is for the TCC lockup.
peace
Hog
Old 05-07-2013, 11:14 AM
After cleaning it up I noticed there is the-375 written on it so I'm thinking this was put in in place of the the stock one because the torque converter was replaced as well
I meant to put th-375 sorry
Old 05-07-2013, 03:21 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The TH350C has an electrical plug adjacent to the shift shaft. Some were 4 prong, square plugs and others were two prong like shown below:
th350c, trans id
T-350 question 67MercCat Transmission - Rearend 3 08-17-2012 08:44 PM
th-350 question untchable502 Transmission - Rearend 3 02-25-2008 07:46 PM
350 some question Parisienne70 Engine 1 12-10-2007 06:08 PM
350 question Parisienne70 Engine 3 11-14-2006 02:59 PM
Th-350 Question T-bucket23 Transmission - Rearend 3 08-31-2005 11:06 AM
