T-350 rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2011, 09:48 AM
T-350 rebuild
alright so the th350 in one of my Chevy's pooped out. I've replaced 2 before so I know
how to take them out n put them in. don't have much money to spare so I'm gonna try
to rebuild it. is there a how to or anything? I looked around but didn't find anything.
are there any good gear kits you can recommend? input is greatly appreciated
Old 09-22-2011, 10:15 AM
1984chevypickup's Avatar
I would look in other threAds on here you might find them helpfully because that's what I did when I was trying to find out sone info about my turbo 350 but I know there are rebuild kits out there and what's it going into and what is it used for I Also know kegs and summit have some for like 1500 or something which is not bad when you look at all the time and how
Much parts are if you have the money
Old 09-22-2011, 11:32 AM
TH350 Rebuild
Crosely he is the transmission goo-roo on here and has a nice piece on rebuilding the th350. If it is moderate to stock rebuild you don't need to waste money on an expensive summit brand kit. I get mine through APT and my local Part Plus supply sells them for 80.00 and it is complete to include a filter and modulator. Even Autozone or Checker has master kits you can get for about 100.00 that will do you just fine and have everything you will need. The th350 build spec list of instructions that Crosely has posted, just follow it to a T, and you should have no trouble getting it together and working. Just make sure you take it one step at a time and don't mix anything up, bolts etc. Just label it and keep everything as one unit until you rebuild it and then set it off to the side as a rebuild unit.
Old 09-22-2011, 06:38 PM
Crosley's Avatar
Wiki Edits: 1659
Start here in the Crankshaft Wiki:
clik here
Old 09-23-2011, 06:50 PM
turns out its a 700r4. any tricks on how to pull it out? I've been having a hell of a time
trying to wiggle it out. the Guy my dad bought the truck from threw a built 350 in it
when the v6 in it went out.
it wont go into any gear. that's why I'm pulling it. what's your opinion on it crosely?
and I read some more stuff bout rebuilds. kinda scared to tear her down now Haha
thanks guys.
Old 09-24-2011, 09:53 AM
If your doing it cheap and yourself a th350 is better to start with, that is rebuilding your first transmission. You can find cores cheap around if you look. If its 2wd you can get a long th350 9 inch tailhousing and it will bolt in, if it 4wd you will need a spacer adapter and a longer output shaft. If you are going to try and rebuild the 700r4 there are again some nice cheap kits out there. You can go with a commercial 3-4 clutch pack, a shift correction kit, beast sun shell, and a .500 boost valve and that should take you pretty far. Lots of you-tube videos for 700r4 and 4l60E's. And of course get a book, Chilton's has a GM transmission book that you can get at autozone for $30.00. This book covers the th350 and th400, 700r4, and 200r4. And it also covers front wheel drive GM transmissions
Keep and rebuild flat tappet 350, or try and get roller cam 350? jsm1847 Engine 2 06-04-2012 10:03 AM
72 350 rebuild huyett4 Engine 1 02-19-2012 05:01 PM
350 Rebuild 1970 CST/10 Engine 19 11-21-2010 11:43 PM
what how to rebuild my 350 for about 350-400hp ilehmansabel Engine 6 01-17-2006 09:28 AM
350 rebuild grandprix601 Engine 2 09-18-2005 09:06 PM
