T-350 rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2013, 06:19 PM
T-350 rebuild
I have a B M shift kit i installed about 16 years ago. It came with 3 options towing/street/and race. I chose race which made it a manual valve body, I had to plug the vacuum modulator and take out if i remember right 3 check balls. i am rebuilding the 350 now and i was wondering if this kit "dual feed the clutches" i wanted to internally dual feed the clutches. Is it a good idea to internally feed and dual feed from valve body?
Old 02-24-2013, 02:28 AM
pricesgarages's Avatar
the b and m transfer plate does a good job of suppling fluid ive done the dual feeding on transbrake units ive done but i dont on my street units dont see the need in it plus it looses psi in reverse
Keep and rebuild flat tappet 350, or try and get roller cam 350? jsm1847 Engine 2 06-04-2012 11:03 AM
350 rebuild tweng1 Engine 2 05-30-2010 07:15 AM
first 350 rebuild campracing Engine 8 09-10-2009 02:30 PM
T-350 Rebuild Mr. Smith Transmission - Rearend 1 07-29-2008 01:48 PM
what how to rebuild my 350 for about 350-400hp ilehmansabel Engine 6 01-17-2006 10:28 AM
