T-350 rebuild for 400hp - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2011, 11:40 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
hey guys... I am sure this topic has been beaten to death but ive been spending a while on multiple different forums including this one and haven't seen a list of parts that should be replaced at certain hp levels... if there is one can you please post the link if not please educate me as much as possible!
I want to put a 200-4r in my car but my certain financial situation is not gonna allow me to do that. So i figured I would consider rebuilding my current TH350 that is in the car. My dad got it from a late 70s caprice I believe and sometime in the early 90s installed a b&m shift kit into the trans.... other than that it is stock.
Soon I will be dropping in a 355 that should be making around 400 hp and 400 tq. I was wondering what I should do to the trans to make sure it lives. The trans is good right now shifts hard for every gear... from 1st to 2nd it engages the seat belt locks I have a 3200 stall redneck racing converter along with a deep aluminum vented pan and an extra cooler up front. I figured I would start with the basic rebuild of clutches, seals, gaskets.... Is there any hard parts that I should have to replace? any suggested kits? I wouldn't mind keeping the shift kit in it now... but whatever you guys think will be best. Thanks in advance!
Old 05-01-2011, 04:09 PM
SSedan64's Avatar
What should be Upgraded is covered here>> http://www.crankshaftcoalition.com/w...0_Rebuild_tech
Most of the B&M kits are hard on parts.
Old 05-08-2011, 07:05 PM
Listen and Learn
Wiki Edits: 7
well... Just ordered the book... made a 3' x 8' table today to lay all the parts out on. So after reading through that link it seems that no hard parts need to be replaced for my hp goals. Is this true? I will have the direct piston machined down for the 5 clutches. I am going to have my local trans shop do it for me. and other than that just get a rebuild kit with new bushings, clutches, seals, and gaskets. Thanks in advance everyone!
Old 05-08-2011, 07:40 PM
Listen and Learn
Wiki Edits: 7
I am also considering dual feeding the direct drum. I just read through that link again and I will be taking the builders advice and replacing the intermediate roller clutch, hardened intermediate sprag race, and intermediate sprag.
Old 05-09-2011, 08:31 AM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
you shouldnt have to do that to make it handle 400 hp/tq. i rebuilt mine and did only a B&M clutch and pressure plate upgrade and it has held up to my 550HP/TQ BBC.
Old 05-09-2011, 06:37 PM
you definaltly want to get a hardened sprag race and maybe even a sprag conversion for the intermediate I think Jake sells a kit for that pretty cheap.
Old 05-10-2011, 07:12 AM
Listen and Learn
Wiki Edits: 7
Thanks for the replies everyone! Tear down should begin today or tomorrow and I will post pics.
Finishing off Year One 350/400hp petes67bird Engine 5 06-02-2010 08:42 PM
Need Help Getting 400hp Out Of My 350 ray ray Engine 2 08-26-2009 09:36 AM
build me a 400hp 350 F3RR3T Engine 15 09-06-2007 05:26 PM
what how to rebuild my 350 for about 350-400hp ilehmansabel Engine 6 01-17-2006 09:28 AM
good rebuild for T-350 400hp+ roy383ci Transmission - Rearend 11 06-09-2005 03:02 PM
