I have a custom "a- team" style GMC Beauville. I just rebuilt the transmission (only clutch plates, seals and steels) the rest was in good shape but there was no surfaces left on forward moving clutch plates. I have it all back together and in the van. It is operated via a chevy 350 small block. Before I go ruining all the hard work I have put in, what do I do next to ensure that I cam get the van to move? I heard something about priming the system? Do I have to bleed out the air? How much fluid will I need? (Yes everything went back in to the trans as i replaced portions) THERE WERE NO EXTRA PARTS I FORGOT TO INSTALL. Please help me learn what to do next. It is my daily driver and I need to get her rolling again.
For instance.... if you dont have enough brake fluid and too much aor in the lines the brakes wont work... not saying I have tried this, but is it safe to imagine that if you dont have enough fluid in the transmission that it wont engage? When shifting through gears?
I imagine without enough fluid it wont move? Do i run the fluid until it gets hot before adding more fluid? And ive been working on this thing alone, so i may have put the transmission cooling lines in the wrong order on the transmission itself. The lower line out of the trans is going to the top of my radiator just below the fill cap. The upper port is connected to the low end of the radiator.
Do what stuarts said. Don't try to drive until you have fluid visable on the dipstick. Then put the transmission in drive just to let it engage. Then put it in reverse and just let it engage. Then check the fluid level. I like to have it on a quart low level until it warms up so I don't overfill it.
Thank you kindly! I figured the fluid played a huge role for to move forward and backward. I'll be back out on her in about an hour and I'll let you guys know how it went. But does it matter if I have the trans cooling lines a certain way because I can't for the life of me remember how they go and my Haynes manual is useless to say the least...:smash:
Doesn't matter with way the cooling lines go. It is just a circulation circuit through the cooler. Make sure you flush the cooler and lines real good. Wouldn't want to push all kinds of junk in a new rebuilt transmission.
Runs like a Beaut!( minis the broken spark plug) THANKS GUYS!! Ive sucessfully rebuilt my firstbtransmission!.... Now to can that taiwanese starter... POS
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
