T-350 rebuild question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2013, 07:18 PM
I am rebuilding my first transmission and have a considerable amount of rust on sun gear shell and drums ( some on inside of shell and drums, most on the outside surface. Can this be cleaned and scrubbed with scotch pad and be ok to run. The sprag springs where not perfect either, i re stretched the collapsed ones and they all seem to hold pins well now, 2 pins where slightly scored as well. The sprag went back together ok but is a little bit tight, is this a problem or will it be sufficient. Any comments or opinions will be greatly appreciated.
Old 07-22-2013, 09:36 PM
pricesgarages's Avatar
replace the sprags there cheap dont risk it check bushings close
rebuild, th350, transmission, turbo350
89 350 engine rebuild question ChevyTruckGuy Engine 3 11-11-2010 06:30 AM
T-350 rebuild question Marcus Transmission - Rearend 3 07-01-2004 07:48 PM
350 Chevy Rebuild question? shockers69 Engine 9 12-12-2003 01:52 PM
350 engine rebuild question (long) 84bird Engine 4 07-23-2003 05:48 PM
th-350 rebuild question b/w72 Transmission - Rearend 2 03-16-2003 09:30 AM
