T-350 Rebuild questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2002, 10:45 PM
Help! I have a TH350 in a basket(completely disassembled) and a TCI rebuild kit. Also a haynes TH350 manual. The manual keeps referring to reinstall in the same order it was disassembled. Since I didn't take it apart I don't know the order. Is there any sorce of technical information I can locate that will tell me exactly how to reassemble a TH350.
Note: I am stuck in the middle of the jungle in Indonesia so its not like I can run down to the local parts store or Auto trans shop for advice and help.
Any help or advice would be greatly and sincerely appreciated. <img src="confused.gif" border="0">
Old 11-04-2002, 06:20 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
the Haynes manual is very good. Just go the the last page fo the book and follow the picutres and directions backward to the front of the book.
Old 11-17-2002, 04:32 PM
New Member
Post
The Turbo 350 handbook by Ron Sessions will do the trick for you!! Go to your local bookstore, Amazon, Barnes & Noble. Its HP books isbn# 0895860511.
68 Olds 350 rebuild questions boese1978 Hotrodding Basics 8 10-22-2011 08:36 AM
350 Rebuild project questions rp23g7 Engine 11 06-07-2010 01:58 PM
350 Rebuild Questions chevyman06 Engine 1 06-22-2005 10:50 PM
350 Rebuild Questions Grant209 Engine 5 12-30-2003 06:24 PM
