T-350 Rebuild valve body questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2012, 05:32 PM
hey jakeshoe im new on the transmission rebuilt i want to rebuild them all i have already a shift kit from b&m, the question is if i already have this kit could i make the dual feed for the direct drum by blocking the hole on the case??? can you explain me about the 2-3 accumulator block and what about the 1-2 accumulator??? i want to learn more abouth this part how do i block it??? if you can attach some photos this could be great
regards
Old 01-22-2012, 07:13 PM
Crosley's Avatar
Wiki Edits: 1659
I brought your post in to a new thread.
Jake pops in on this site now and then.
THe Crankshaft wiki has more information on the t-350 mods Clik here
Power Glide valve body questions Overdriv Transmission - Rearend 7 12-31-2011 12:40 PM
TH 350 Reverse Manual Valve-body Questions qsharp84 Transmission - Rearend 2 11-27-2011 04:00 AM
TH350-TCI manual shift valve body questions.... Coletrane Transmission - Rearend 2 04-23-2010 05:39 AM
New 350 valve body vs 350 Valve body reprogramming kit terminator0723 Transmission - Rearend 4 04-14-2009 07:41 PM
T-350 Valve Body Rebuild Question jnobody Transmission - Rearend 2 04-02-2009 05:05 PM
