T-350 shift kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2011, 09:01 AM
T-350 shift kit
Okay so I am doing a complete swap from v6 to v8 and have a th350 good to go, but before I put it in I have heard that you can do an "at home" shift kit by drilling out some things. So has anyone heard/know how to do this? Maybe my buddy was blowin smoke, but figured id ask before its in. thanks
Old 03-24-2011, 11:21 AM
tnsmith10's Avatar
when will it rain???
there are a few things you can do to increase shift feel without installing a kit for this trans.
the easy things that can be done are to remove the 2-3 accumulator spring in the valve body, and to block off the 1-2 accumulator in the side of the case.
drilling holes in the separator plate can benefit or hurt you depending on what your after, and without doing the additional modifications that come with a kit can give you adverse reactions to what your truly after.
transgo makes a kit that is simple to install and helps give you what your after. its a 350 1&2. heres a link to the site, the kit is a little more than half way down the page. also, they have an install video you can download to help with instructions (a bit vague) and installation. hope this helps
Old 03-24-2011, 12:13 PM
Okay maybe I should've specified, im upgrading to a mainly stock sbc350 with a mild RV cam and a 600 Holley, so nothing too radical, but is still an upgrade for a v6. So im not necessarily out to get the biggest bang for right now. I am looking for the link that was on the page (im very new Hotrodders.com) so maybe a highlight of the link would be helpful. But as far as the feel its a daily driver so i especially dont wanna go outrageous on mods for the tranny but something dependable and has some thrust if this makes any sence. Thanks!
Old 03-24-2011, 05:30 PM
tnsmith10's Avatar
gads... im sorry there man, i cant believe i forgot to post the link. sorry, its been one of those days...
how about this?: http://www.transgo.com/rpg_generalmtr.php
as far as what i told you on the DIY without the kit. its nothing fancy, 350's have a soft 3rd gear for the most part anyways, and usually, i toss the 2-3 accumulator spring when i build a 350. as far as the blocking off of the 1-2 accumulator, i dont do that, but its something i know people have done to give a better 1-2 shift.
Old 03-25-2011, 03:45 AM
SSedan64's Avatar
Jake shows the DIY shift kit Info in his 350 Build>> http://www.hotrodders.com/forum/th35...ch-145361.html
Old 03-25-2011, 07:02 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Jakeshoe's t-350 article is in the Crankshaft Wiki clik here ... I have been cleaning that article up a bit, added some more photos
Old 03-25-2011, 10:02 PM
SSedan64's Avatar
Looks good Crosley. Is Jakes 400 build in the Wiki also?
T-400 Build Tips with Photos
Old 03-25-2011, 10:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
yes, if you navigate the Crankshaft Wiki Transmission page
clik here
.. you will see several articles there that may help folks. A link can be posted to the Wiki on this board to various articles
Old 03-26-2011, 06:04 PM
Wow thanks tnsmith that is the best guide Ive seen and it helped alot.
can i use the 700-2-3 Shift Kit with the B&M Shift Improver Kit in my 1985 700r4 84chevyc10 Transmission - Rearend 8 01-16-2012 12:05 PM
T-350 what shift kit? cutthroatkid Transmission - Rearend 9 09-15-2009 05:45 AM
Th-350 Shift Kit GoneNova/406 Transmission - Rearend 0 10-18-2005 11:57 PM
350 turbo shift kit 72chevy cruisin Transmission - Rearend 4 09-02-2004 07:56 AM
th-350 shift kit ideas cragars Transmission - Rearend 4 05-05-2004 08:48 PM
