Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 Shift Kit
Thread: T-350 Shift Kit
Old 03-21-2014, 07:50 PM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
If you save the stock pieces that you remove, they can be re-installed to return the valvebody to stock. As long as you are using a kit that comes with a new separator plate, otherwise you will have to get a stock plate from a trans shop.
This is based off using B&M, Hurst, and Fairbanks kits in the past...I'm not familiar with how Trans-Go does it.
