T-350 shift kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2013, 08:37 PM
T-350 shift kit
what is a good shift kit for a th350?
Old 09-28-2013, 11:28 PM
Speedshift_Sam's Avatar
Mekanicus Automotive Group
Depends....
That sort of depends on what you want it to do. Racing? Hot street machine? Most kits come either in a stage one or stage two. The stage one is for heavy duty use, such as trucks and motorhomes, also works well on medium power street machines. Stage two is racing and high power only. So, what are you planning to do?
Old 09-29-2013, 10:19 AM
I am building a mild 350 the cam is 224 224 466 466 so its not a crazy build but I want a sold shift. and its going in a 1983 c10. witch is a good brand of shift kit I hear a lot about b&m but I don't know much about shift kits so I don't want to buy a ****ty kit.
Old 09-29-2013, 11:07 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by gavinjames View Post
I am building a mild 350 the cam is 224 224 466 466 so its not a crazy build but I want a sold shift. and its going in a 1983 c10. witch is a good brand of shift kit I hear a lot about b&m but I don't know much about shift kits so I don't want to buy a low quality kit.
Buy a TransGo 350-1&2 kit
Old 09-29-2013, 11:27 AM
techinspector1's Avatar
Wiki Edits: 326
Shift kits are fun for 10 minutes. After that, they are just a pain, jerking your head back on every shift. I had a shift kit in a street car once. ONCE. Use a looser converter with it to ease the shift a little.
Old 09-29-2013, 12:08 PM
Proud LOSER
I have used TCI, B&M, and trans go, I even have a home built kit in my DD grand marquis, (by far the hardest shifting of any of them) and the trans go has the most comfortable shift, the B&M hits the hardest out of the store bought, chirps the tires on anything over half throttle, but the Trans Go isn't real intrusive until your on it hard. Depends on what you like. Tech isn't a fan of tire barking sillyness (but he's old ) while I love it to tear my face off at every shift....pic your poison.
(Make fun of my spelling eh Richard ) lol.....
The Following User Says Thank You to bygddy For This Useful Post:
techinspector1 (09-29-2013)
Old 09-29-2013, 03:13 PM
[QUOTE=bygddy;1798370]I have used TCI, B&M, and trans go, I even have a home built kit in my DD grand marquis, (by far the hardest shifting of any of them) and the trans go has the most comfortable shift, the B&M hits the hardest out of the store bought, chirps the tires on anything over half throttle, but the Trans Go isn't real intrusive until your on it hard. Depends on what you like. Tech isn't a fan of tire barking sillyness (but he's old ) while I love it to tear my face off at every shift....pic your poison.]
So with a B&M if you drive it easy and keep the throttle less than half you won't have tire chirp on up-shifts?
Once the shift kit is installed can it be removed and the trans returned to stock condition?
Are there any other shift improvement options available?
My 70 LeMans is a mild street build with a 400, headers, 224\234 cam, 2300 rpm stall converter and stock th350. I am looking for a shift kit that will give tire chirp when driven hard but no chirp when driven easy. Sounds like the Trans Go is the one for me.
bt
Old 10-07-2013, 10:04 AM
Rodnit's Avatar
I have a Hurst and it chirps if you don't drive it easy..... It's fun to shift manually however.....
can i use the 700-2-3 Shift Kit with the B&M Shift Improver Kit in my 1985 700r4 84chevyc10 Transmission - Rearend 8 01-16-2012 11:05 AM
T-350 shift kit 91CamaroDude Transmission - Rearend 8 03-26-2011 05:04 PM
T-350 what shift kit? cutthroatkid Transmission - Rearend 9 09-15-2009 04:45 AM
Th-350 Shift Kit GoneNova/406 Transmission - Rearend 0 10-18-2005 10:57 PM
350 turbo shift kit 72chevy cruisin Transmission - Rearend 4 09-02-2004 06:56 AM
