T-350 shift problem. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-26-2011, 12:44 PM
Yeah..if you look hard enough you can find someone that will come to your house and install the trans for you.. my buddy had both of his cats go out in is Audi A4..The guy came out cut the old cats out and welded new ones in, the mechanic provided the cats, the tools and the welder..did all the work in my buddies drive way for 450 bucks...very very reasonable prices are out there.. you just need to look.. good luck. and if your not already...join
Maliburacing.com its a forum just for G-bodies, everyone there is real nice, full of knowledge and always happy to help..
  #17 (permalink)
Old 05-03-2011, 09:20 AM
JLBpontiac350's Avatar
85' grand prix,th200M,chev305
UPDATE! strange but success...
so if your read throught the thread i foundout many things. i actualy have a th200c not a th350. and many people told me it was many differant things of why my trannys was slamming into second and not shifting into third. so figured i would pray to god it helped and just do a fluid flush and filter change. guess what! there IS a car god because it worked! i couldnt belive it myself but all of my problems where resolved with this. BUT when i first did the fluid change and filter change it didnt help at all..i changed fluid and filter started it up slowy shifted through all the gears then took it for a ride and no change. then today i decided to drive to th store and it just started shifting great! idki if the new fluid just needed time to run through the tranny or what but it shifted smooth into second and right into third. i cant belive my luck im poopin rainbows and gigglin like a girl. thanks for all the advice guys! pleas read my tachometer hookin up thread!
  #18 (permalink)
Old 05-03-2011, 10:45 AM
how many quarts of fluid did you put in it? Did you actually flush the trans or just drop the pan?
  #19 (permalink)
Old 05-03-2011, 10:55 AM
did it the cheap way because i had to make time, im not "allowed" to work on cars where i live. i droped the pan. 4 qts came out so i put 4 qts in and a half a bottle of lucal tranny stop slip/ shift hard. seems to have done the trick.
Turbo 350 2-3 shift problem tryanswri Transmission - Rearend 6 08-30-2010 07:52 PM
Shift Problem - TH-350 nova69 Transmission - Rearend 4 08-03-2008 08:41 PM
Shift problem FlamingZ28 Transmission - Rearend 5 03-17-2006 03:04 PM
1-2 shift problem 1964chevelle Transmission - Rearend 2 09-28-2005 09:14 PM
350 shift problem idid35 Transmission - Rearend 6 01-26-2004 07:14 PM
