Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 shifter bracket
Old 01-29-2004, 09:53 PM
BstMech's Avatar
BstMech BstMech is offline
NYOFP4RJ3CHRIS
What I've always done is place the select lever to park on the tranny, then place shifter to park as well. You can then place the cable where it's gonna ride (just below the pan lip) and take a measurement. This will get you in the ballpark, you can fine adjust it with the adjustment nuts. If you don't have adjustment nuts on your cable, you can still tweak the bracket a little to get it where you want it.
