T-350 Slipping at med-high RPMs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2013, 06:11 PM
Hi Guys. This is my first post; I hope someone can help me diagnose my problem.
I have an '83 Chevy Silverado with a stock 305 and stock TH350 transmission. I bought the truck with an existing transmission problem...
The transmission takes a second or two to go into gear from Park and has a slight amount of pull in each gear (if I manually shift through the gears), but in med to high RPMs it slips; this happens in every gear. Reverse is very strong and does not slip at all. Also, I have to manually shift from 1st to 2nd to 3rd. Every once in a while it will shift through the gears on its own, but not very often at all. I've also noticed a VERY slight amount of vibration when at a stop while in gear.
I recently changed the fluid and filter and the fluid level is fine. It also has a new modulator and the vac line seems to be ok.
Could this be my torque converter?
slipping, th350, transmission
v belt pops off under high rpms zildjian4life218 Engine 19 08-03-2011 11:38 AM
Rpms too high prettyboyced Transmission - Rearend 25 11-26-2010 05:28 PM
Too many Rpms - Convertor slipping or stall speed too high? heyjude076 Transmission - Rearend 2 09-17-2008 01:32 PM
TH400 shifting high rpms dieselherb Transmission - Rearend 1 08-20-2006 11:56 AM
Car is smoking at high rpms... redcamaro4spd Engine 4 12-23-2003 05:15 PM
