-   -   T-350 : slow going into reverse gear (http://www.hotrodders.com/forum/t-350-slow-going-into-reverse-gear-224051.html)
wayneooo 09-16-2012 05:07 AM
turbo 350 with a B&M ratchet shifter..drive works fine u can fell it click in but it takes a while to go into reverse.this is in my casket car afraid to rev the engine to much and have the thing take off 20 mph backwards but when it clicks in the car should start to move by its self right? the converter is stock no high stall one,bad bands ??? any way to adjust it w/o complete rebuild?????????????
SSedan64 09-16-2012 07:52 PM
No adjustments.
Low pressure, Direct or Low/Reverse clutch seal problems.
Ruthlessmr 09-16-2012 11:50 PM
tear the valve body out and pressure check it but its prob a broken or cut seal
