T-350 : slow going into reverse gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2012, 04:07 AM
turbo 350 with a B&M ratchet shifter..drive works fine u can fell it click in but it takes a while to go into reverse.this is in my casket car afraid to rev the engine to much and have the thing take off 20 mph backwards but when it clicks in the car should start to move by its self right? the converter is stock no high stall one,bad bands ??? any way to adjust it w/o complete rebuild?????????????
Old 09-16-2012, 06:52 PM
SSedan64's Avatar
No adjustments.
Low pressure, Direct or Low/Reverse clutch seal problems.
Old 09-16-2012, 10:50 PM
tear the valve body out and pressure check it but its prob a broken or cut seal
4L60E slow to engage 1st and reverse 72firechicken Transmission - Rearend 4 07-17-2011 11:21 PM
TH 350 lost 3rd gear and reverse is weak junior stocker Transmission - Rearend 1 05-29-2009 04:20 PM
4l60E Slow Reverse jadejoky28 Transmission - Rearend 4 05-21-2009 10:41 AM
700R4 Slow to shift into Reverse rudeg Transmission - Rearend 4 02-26-2007 10:09 PM
New TH 400 slow into drive and reverse Jmark Transmission - Rearend 2 02-09-2004 10:39 PM
