t-350 speedo gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2009, 07:10 PM
Th350 Drive Gear Color / Tooth Question
JON69 SAYS HIS TH350 HAD A GREEN 7-TOOTH DRIVE GEAR ON OUTPUT SHAFT BUT TCI CLAIMS THE GREEN GEAR IS A 9-TOOTH UNIT. WHICH IS TRUTH HERE AS I DO NOT WANT TO PULL TAIL HOUSING OFF JUST TO COUNT TEETH SO I CAN ORDER THE PROPER DRIVEN GEAR. MY TH350 HAS A GREEN GEAR ALSO AS IT WAS INSTALLED WHEN PURCHASED FROM TCI IN 1990. JUST NEED TO KNOW IF THE GREEN DRIVE GEAR IS 7T OR 9T.
THANKS FOR ANY HELP. STEVE 383mc
Old 07-19-2009, 09:10 PM
302 Z28's Avatar
Please turn off you caps lock, it is considered shouting to post all in caps.
Vince
Old 07-20-2009, 04:53 AM
tnsmith10's Avatar
when will it rain???
if the trans was purchased through tci, and the speedo parts have never been changed, then id have to agree with tci. theres a few different manufacturers that produce speedo gears, and they dont carry the same colors as others per tooth count.
Old 07-20-2009, 09:19 AM
Wiki Edits: 85
I ignore anyone who SHOUTS at me.
Old 07-20-2009, 09:39 PM
The green one that I put in my Suburban had 9 teeth. Probably still does.
