T-350 speedo gear question? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-31-2012, 11:26 AM
Wiki Edits: 85
Originally Posted by tobyj17 View Post
I haven't ordered the gears yet, but i did finally get the speedo hooked up, 30 mph off!
One thing i forgot to ask, are these gears the same with a TH350 and Th 350c?
30mph of when you are going 5mph is a whole lot different than 30mph off when you are going 100mph. Basically, without a reference point, 30mph is MEANINGLESS.
TH350 and TH350C output shafts are interchangeable back and forth, so all drive gears that fit one will fit the other.
As Crosley has noted, the driven gears depend on the tail housing used. Generally, but not always, the small hole type is used on Chevys while the large hole type is used everywhere else.
  #17 (permalink)
Old 08-01-2012, 02:47 AM
Wiki Edits: 85
I meant to say:
As Cobalt has noted, the driven gears depend on the tail housing used. Generally, but not always, the small hole type is used on Chevys while the large hole type is used everywhere else.
Firebird with T-350 speedo gear change question f/bird Transmission - Rearend 4 06-09-2012 04:46 PM
speedo gear color question hddave1 Transmission - Rearend 1 03-15-2011 09:16 PM
2004R Speedo Gear Question Zeeb Transmission - Rearend 12 08-20-2010 07:58 PM
t-350 speedo gear 383mc Transmission - Rearend 4 07-20-2009 09:39 PM
TH 350 Speedo Drive Gear Mr Bob Transmission - Rearend 11 01-12-2007 05:37 AM
