T-350 with a stuck kick down cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2012, 01:02 AM
V305's Avatar
On the Border
I noticed yesterday when I was checking my carb that my kick down cable from my trans is pretty much stuck, I can move it a little, but is not returning to it's position , it's hard to move, looks like I have to remove the pan to see what's going on. Any thoughts before I do this? Any suggestions are welcomed , thanks
Old 10-27-2012, 04:02 AM
SSedan64's Avatar
Many times they get burnt by Headers, pinched, frayed inside etc.. May just need a new Cable.
Old 10-27-2012, 06:34 PM
V305's Avatar
On the Border
That is the thing, the cable its new, a mechanic installed this cable for me a year ago and its not touching anything that could damage it, looks like I have to drop the pan to see whats going on.
The Following User Says Thank You to V305 For This Useful Post:
chuck M (10-27-2012)
Old 10-27-2012, 07:40 PM
chuck M's Avatar
I just rebuilt a 350 and got a valvebody from a friend. The little lever bolted to the valvebody that the detent cable hooks to was bent and broke.So that is possible. what i would try first is to unhook your cable at the carb then unhook from trans. There will be a stiff piece of wire running into the trans that will detach from the cable once you pull the insulation of the cable up far enough. be ready with some needlenose vise grips to hold the wire coming out of the trans. once secure you can pull on the stiff wire to see if it is infact operating properly inside the trans. You should feel slight pressure followed by more pressure for the last 1/2 inch or so. If you feel that your cable should be replaced. If you dont feel it or it does not return once you pull it you should pull the pan an valve body to inspect the valve and springs.
The Following User Says Thank You to chuck M For This Useful Post:
V305 (10-27-2012)
T-350 kick down cable needed? cbrock420 Transmission - Rearend 1 12-13-2011 03:31 AM
350 turbo leaking at kick down cable. 40forddgc Transmission - Rearend 5 01-07-2010 08:37 AM
T- 350 Kick Down cable adjustment? 49chevytruck Transmission - Rearend 4 07-31-2008 05:26 PM
kick down cable jettajo42 Transmission - Rearend 1 06-16-2008 04:34 AM
700R4 Kick stuck?? omega69 Transmission - Rearend 7 05-25-2008 12:26 AM
