T-350 to T-400 tranny swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2011, 09:35 PM
Originally Posted by Chazmac
Short tail 350 and short tail 400 are the same length, only requires slip yoke change. If you go to two piece driveshaft, use a bolt-on yoke 400 if possible.
Short tail is ~6" long
I know its old but this threat fits my question and I figured why start a new one right? So I have a C10 with a TH350 with a 6" tailshaft and wanna use a TH400 4" tail.. So I could just change the slip yoke and be good to go then? What about the transmission mount location? Does it have to be moved? Can I re-use my crossmember?
Greg
Old 06-13-2011, 06:05 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Greg
The old thread was 6+ yrs old. Some members no longer visit here.
Cross member can be moved, modified as needed
Old 06-13-2011, 06:21 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Greg
The yoke needs changed, drive shaft will be about 1.375" too long**, otherwise move the X-member rearward, the holes should be there already.
**This is the difference between the two transmissions using published lengths. This does not take any other variables into consideration. You MUST ACTUALLY MEASURE to be absolutely sure how much difference there actually is.
http://www.maliburacing.com/auto_tranny_id.htm
Nailhead T-400 tranny with manuel valve body swap to back to auto Petematthews Transmission - Rearend 11 11-12-2011 01:13 PM
upgrading from a 350 tranny to 400 angel85lx Transmission - Rearend 2 09-01-2011 08:55 PM
350 sbc and 400 tranny 49dream Transmission - Rearend 5 01-26-2006 01:30 AM
tranny 350 or 400 heavychevy70 Engine 7 03-17-2005 04:28 PM
installing a 350 or 400 tranny zeeman19 Transmission - Rearend 4 07-02-2002 05:18 AM
