Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 takes off in 2nd gear
Old 03-06-2013, 05:45 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by runn141 View Post
you are exactly right about that, but you waited almost 24 hours for me to reply before you corrected me on that. the OP could have went and got the wrong governor in that time. if the OP did in fact get the wrong governor from the false info i gave, your just as much to blame for it as i am. because you didnt point out the facts in your first quote.
You are incorrect again. I did not know what you had in mind on the governor interchange. That is why I asked for an explanation and did not "assume" anything.
When your answer was that you really had no clue of the information you posted, I provided the correct the information.
You are one of the folks on the internet that spread incorrect information on transmissions that I have read for years. It is not a malicious spreading of mis-information, it's just posting information that you "assume" is correct.
If you would have posted the information as a possible answer and that you were not sure of accuracy, then I would have corrected the info quicker.
