Check the shift linkage adjustment and the governor. Governor is under the round press on cover at rear of main case side
At the Bonneville Salt Flats, first gear is known as 130 mph. |
turbo 350 takes off in 2nd gear
I have checked governor and appears ok.Took apart and re-installed.Also have aftermarket kit with different weights and springs,right now it contains the originals.Have re-adjusted shift linkage several times.
Please explain how these 2 governors would interchange with a T-350 governor
just because weights will interchange , the whole governor will not directly interchange
You could have posted that you were assuming the governors all interchanging. The incorrect information could have sent the OP off on a wrong track for a replacement governor.
When your answer was that you really had no clue of the information you posted, I provided the correct the information. You are one of the folks on the internet that spread incorrect information on transmissions that I have read for years. It is not a malicious spreading of mis-information, it's just posting information that you "assume" is correct. If you would have posted the information as a possible answer and that you were not sure of accuracy, then I would have corrected the info quicker.
At the Bonneville Salt Flats, first gear is known as 130 mph. Last edited by Crosley; 03-06-2013 at 05:55 PM. |
| 82 elcamino slips when maually put in 1st, 2nd, or drive but takes off fine from OD | sanawa | Transmission - Rearend | 0 | 01-24-2012 02:36 PM |
| 350 turbo trans takes off in 2nd | stanjr41 | Transmission - Rearend | 2 | 01-23-2012 02:16 AM |
| missing 2nd gear in T-350 trans | low_and_slow | Transmission - Rearend | 1 | 08-15-2011 11:50 AM |
| Running th-350 in 2nd gear? | Phoneguy | Transmission - Rearend | 10 | 11-23-2009 06:52 AM |
| 350 jumps in to 2nd gear | roooon | Transmission - Rearend | 2 | 11-13-2005 07:18 AM |
