T-350 third gear problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2012, 01:43 PM
hey guys,
so after putting around town for a few days and a couple trips on the highway at 55 mph. I notice my tranny isn't going into 3rd unless i really kinda hammer on it and give it some throttle.
i checked the obvious first, vacuum lines, new vac mod valve, fluid levels, still has the third issue. 1&2 are smooth as butter, reverse works great, 2 to 3rd doesn't wanna come in until around 2500 rpm and acts like it wants to slip between the two unless i really put it down on the throttle then it will go into 3rd and hold it, but as soon as i let off it jumps right back to 2nd. any ideas?
Old 10-29-2012, 02:18 PM
crosley, any ideas?
Old 10-30-2012, 06:07 PM
So..no one
Old 10-30-2012, 07:44 PM
Crosley's Avatar
Wiki Edits: 1659
typical 3rd gear problems you describe are related to pressure leaks or low vacuum.
Low vacuum, vacuum leaks, clogged vacuum line, wrong connection for vacuum.
Pressure internal leaks, governor problems, leaks, worn governor gear or governor bore or the governor shaft.
Detent cable not adjusted correctly
The Following User Says Thank You to Crosley For This Useful Post:
luckydrummer (10-31-2012)
Old 11-01-2012, 07:52 PM
lucky drummer
do you know this trans is ok internally some history would help
Old 11-01-2012, 07:57 PM
read the pressures first
Old 11-07-2012, 06:13 PM
no idea on the history of it.
gear drives problems notakit Hotrodding Basics 2 08-13-2011 10:53 AM
t350 gear changing problems benns Transmission - Rearend 1 11-03-2009 05:43 AM
Th350 problems.. 3rd gear lugnutz Transmission - Rearend 1 08-29-2007 07:33 PM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
No more dist gear problems! Knobie Engine 1 10-16-2003 05:46 PM
