Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 trans no forward gears work but reverse still works
Old 02-29-2012, 04:51 PM
John Se John Se is offline
this is a common failure mode for those transmissions, all the old guys know about it, luckily a rebuild trans is not a giant expense, 200 or so, if you can do the R&R.
but since it sat you could try and drain it out and replace the fluid, maybe some junk got loose and plugged up a passage.
