T-350 trans problems? Truck lost power - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2013, 01:24 PM
Just put in rebuilt th 350 from rpm transmissions, then he reccomend I use a 21-22 stall converter, so ive installed it and broke it in easy. Im driving a short bed 84 chevy truck. Now with different converter and trans it's straight up weak. Truck gets hot and just lugs. I recently had tci th-350 it would really get up and go but I lost third and did the swap
Old 05-23-2013, 01:27 PM
converter
I purchased stalk converter 1500 stall does anybody know if I will regain my power from the 2100 stall to 1500
Old 05-25-2013, 09:28 AM
T-350 problems
Can anyone tell me if I put to high of stall torque converter in got 21-2200 stall converter. I just put rebuilt trans too. Now the truck has no balls. The trans I took out was a th 350 with 14-1500 stall, which really put out a lot of power. Can anyone give me some advice?
Old 05-25-2013, 02:13 PM
Last journal entry: MY WIFE'S NEW REFIGERATOR
Coverter Dilemma
Is your engine stock or modified? If it's stock, you don't need to increase the stall. If you have put in a larger cam, you need to look at the spec sheet for the cam and get a converter that matches the lower RPM of the cam. It doesn't sound like you have made any changes to the engine so I'd put in a converter that matches what you had originally.
Old 05-25-2013, 05:05 PM
Z27LS3's Avatar
put the old converter back in, it was better matched.
you only need the performance converter with a build higher HP engine and I dont see anything about a performance engine mentioned.
i have a 70's 350 dilema its a 350 out of old truck 2 barrel i need more power johnstubbs Hotrodding Basics 3 01-28-2012 04:05 PM
2000 chev S-10 truck auto trans shifting problems rschatzel Transmission - Rearend 2 10-18-2011 12:35 AM
Chevy 350 lost power with new intake manifold and carb valtiel43 Engine 7 04-28-2011 06:02 PM
A couple problems - TH400 trans and power brakes Torque454 Hotrodding Basics 23 03-18-2010 08:37 PM
Lost power assist !!!! 1970 GMC Truck digtaz Suspension - Brakes - Steering 2 04-16-2003 06:46 AM
