T-350 trans questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2013, 06:28 PM
does this trans suppose to have a tv cable? Isn't it really a passing gear? Is it suppose to be medium tight, I was told if set tight like the 700r, It won't shift into third. I know on a 700r4 ratio is full throttle ea. way, reason I am asking is seems I don't shift into 3rd, I got hose to full intake. I do have a shift kit installed if this makes a difference. I need suggestions, Also on electric speedo hookup on trans, the plastic gear on my trans shaft is green, should the gear that slides in side of trans also be green? thanks Dana (alot of questions, thanks)
Old 09-27-2013, 07:16 PM
Cape Cod Bob's Avatar
I've only done 1 350 and it has a tv cable but wether you use it or not should still shift into 3rd. The colrs don't have to match. You need to know the rear axel ratio, tire cercumference and some other math is done to figure which driven gear is needed for the drive gear you have. . Go to this site for help, Bob.Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
Comcast
Old 09-28-2013, 07:41 AM
thanks Bob for the help
Old 09-28-2013, 08:26 AM
T-350 3rd gear problems
I have same problem, Wont shift in 3rd, my 1st and 2nd gears shift normal and real nice, maybe a little soon but seems ok to me, any other tips
Old 09-28-2013, 09:26 AM
Bob, been doing a little more research, have gotten a few more suggestions about adjusting my governor. Have u taken it out before? If so will anything spring out and screw anything up? Seems there is weights and springs to counter act to give a soone or later 3rd gear shift. I think I should give this a try, maybey got stuck valve or something, thought about cleaning w/brake cleaner. Is there any instruction manual to how to do this etc, thanks again, Dana
Old 09-28-2013, 10:14 AM
techinspector1's Avatar
Wiki Edits: 326
What would I do?
I'd order this book and read through it several times. Note in the header that there are 30 used copies of it starting at $9.00 plus shipping. Pretty much affordable to learn all about your transmission I'd say. I buy used books all the time to save a few sheckels.
Turbo Hydra-Matic 350 Handbook: Ron Sessions: 0075478000517: Amazon.com: Books Turbo Hydra-Matic 350 Handbook: Ron Sessions: 0075478000517: Amazon.com: Books
Old 09-28-2013, 11:33 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Fresh trans or an older trans ?
Where is vacuum source for modulator hooked up?
Does reverse work correctly? NO slipping in "R" ?
Old 09-28-2013, 06:39 PM
trans is fresh rebuild w/shift kit, reverse is perfect, vacuum is hooked to intake between carb abd dist.
Old 09-28-2013, 06:41 PM
spelling, vac. between carb and dist on intake
Old 09-28-2013, 06:52 PM
6.0L with 480 trans or 350 with 400 trans Smokey5150 Hotrodding Basics 8 08-19-2013 12:23 PM
6.2 Diesel to 350 swap "Trans" Questions? frodin1 Transmission - Rearend 25 05-26-2011 11:44 PM
292 engine and 4/5 speed trans questions questions rookiebuilder Engine 2 01-21-2009 05:53 AM
350 trans questions raidmagic Transmission - Rearend 10 04-14-2005 09:33 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
