t-350 trans with stall speed converter problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2007, 01:04 AM
i have a th350 trans i put a shift kit in and a b&m 2000 stall converter its behind a 305 with a mild cam the rear is a 3.07 i think the tires are 295/50 r 15 with the brake on i can get the rpm up to 2500 and do a one wheel peel floored it will shift 1 to 2 at 5000 and chirp the tire.now heres my question idle is about 800rpm when i sit at a light a long time and go to take off i acts like its in neutral and i have to rev it up to 1700 to take off and it grabs hard is this how its supposed to work? never had a higher than stock converter before. thanks dave
Old 12-29-2007, 08:52 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by kwopper07
i have a th350 trans i put a shift kit in and a b&m 2000 stall converter....... its behind a 305 with a mild cam the rear is a 3.07 i think the tires are 295/50 r 15
thanks dave
From your post , It sounds like the trans is dropping out of gear at an idle.
The trans "bangs' into gear as you try to take from a stop after sitting for a short time??
If the trans is dropping out of gear , that is not the stall converter operation. There is a problem with the trans.
Was the trans a fresh rebuild ? IS it a high mileage unit?
what is a stock stall converter for a 350 turbo? batman09 Transmission - Rearend 6 12-05-2004 06:19 PM
stall speed? 70chevyc10 Transmission - Rearend 6 11-23-2004 03:51 PM
Hughes 2500 stall converter s15laynrubba Transmission - Rearend 0 08-10-2003 12:36 PM
Stall Converter novatech Transmission - Rearend 2 07-21-2003 10:24 AM
camshaft help novatech Engine 7 05-29-2003 10:42 AM
