T-350 trans, it wont shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2008, 10:49 PM
i have a 350 sbc with a 350 turbo trans and the problem is that the trans wont shift if im cruising it will only shift if i jump on it . it has a 2000 stall for B&M i check all the linkage and vacuum its all ok
Old 06-16-2008, 12:05 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Just because the modulator is hooked up, doesn't mean that it's doing it's job. Draw a vacuum on it and make sure it doesn't leak off.
If your camshaft has a lot of overlap (e.g. low vacuum signal) the modulator may need to be replaced to an adjustable version to tailor it more closely to the engine.
Always use the stock steel tube or equivalent from a direct intake manifold tap.
If your detent kick down cable is not hooked up and is pulled out, this may be contributing to your problem also.
350 turbo manual shift SAVANT Transmission - Rearend 2 06-14-2007 09:23 PM
350 turbo trans problems,,, tiresmoke55 Transmission - Rearend 10 04-06-2007 09:08 AM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 11:21 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 12:14 PM
