T-350 trans wont shift out of 1st - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2011, 04:03 PM
stanjr41's Avatar
My son has a 76 chevy p/u with a 350 engine/350 turbo trans. Trans probably has 150,000 miles on it,but has always worked fine. Last week he drove it and it would not shift out of first gear. Checked vac lines ,kickdown linkage, and shift linkage. All seem ok. Trying to shift manually thru the gears made no difference, and accelerating to a very hi rpm did not initiate a shift. Oil smells ok and trans has never been abused or overheated. We have owned the truck since new ,so all history is known.
Old 12-28-2011, 04:10 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Have you re-placed the modulator valve yet ?
Cole
Old 12-29-2011, 06:56 AM
tnsmith10's Avatar
when will it rain???
governor gear is applecored or broke. a th350 will still shift with a bad or disconnected modulator
Old 12-29-2011, 03:45 PM
eloc431962's Avatar
Wiki Edits: 37
True.
Cole
Old 12-31-2011, 11:39 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
photo of the T-350 governor and cover. Plastic gear breaks , wears out.
If the plastic gear is apple cored worn... there usually is a cause like worn bushings on the output shaft.
350 turbo trans wont shift targettracer Transmission - Rearend 3 07-06-2011 12:49 PM
my 350 trans wont shift out of 1st gear 86montecarlo Transmission - Rearend 2 04-25-2011 08:26 PM
700r4 trans that wont shift to dr or od emyers Transmission - Rearend 3 03-19-2011 05:51 PM
T-350 trans, it wont shift jettajo42 Transmission - Rearend 1 06-16-2008 12:05 AM
1984 Corvette 700 Trans Wont Shift Up billybonesmusic Transmission - Rearend 3 06-06-2006 08:23 PM
