T-350 transmission assembly problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2011, 09:26 PM
hi i just rebuild my thm350 chevy transmission did everything by the book and all inside parts turn freely and fine but when i install the front pump the input shaft will not turn what did i do wrong.
Old 03-27-2011, 01:02 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Welcome to Hotrodders.com Glad to have you with us
When won't it turn, after you tighten the pump bolts?
Rich
Old 03-27-2011, 05:39 AM
350 trans.problem
Yes when I tighten the pump bolts nothing turns.And how much resistance will will it be on my direct drum before I install the front pump.Thanks
Old 03-27-2011, 08:27 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Check for mis installed thrust washers, clutch teeth not fully engaged, wrong end clearance
Many items can cause this problem. It all is related to proper clearance. If something is in wrong place, not set in place correctly will cause a clearance problem.
Was anything changed at the front end? Pump replaced? drums replaced?
Old 03-27-2011, 08:52 PM
Thank for the advice i will go back and recheck all my step's.I hope it's just a clutch teeth that's not fully engaged.i will let you know.
Problem on the input housing and shaft assembly?? old yukon Transmission - Rearend 1 02-28-2011 08:36 PM
Th350 assembly problem s10mk Transmission - Rearend 3 05-18-2010 03:59 AM
transmission linkage assembly blinky_1986 Transmission - Rearend 1 05-31-2009 02:43 AM
Assembly Rotating Problem Curtis Thornton Engine 29 05-31-2008 10:03 AM
Transmission problem JOE63 Transmission - Rearend 3 01-31-2006 09:51 AM
