T-350 Transmission keeps blowing seals - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2012, 09:32 PM
Hey guys I have a TH350 and I'm having issues with it. At first, it blew the rear driveshaft seal. Then, it started leaking fluid out of the yoke so I sealed it and now it blew the shifter shaft seal. I have a lokar trans dipstick on it and no overflow valve, just a hole where it should be. I tried sticking a screwdriver in the hole to see if maybe it was clogged but I'm not getting very far in without hitting metal. So now I want to know does anyone know how the overflow valve works or how it's routed in the transmission? Does it make a 90 degree angle? What keeps blowing the seals in my transmission?
Old 07-14-2012, 11:13 PM
Wiki Edits: 85
The case vent is probably plugged.
Old 07-17-2012, 01:14 AM
But there is no line sticking out. When I do stick something in the hole, it only goes so far before it stops and hits something metallic
transmission pinion seals for 38 Studebaker 3speed oldmanchopper Transmission - Rearend 6 07-14-2012 08:40 AM
6-71 blown 347 stroker blowing crankshaft seals rojam18801 Engine 3 01-30-2010 12:35 PM
Replacing Transmission Seals 67Elcamino Transmission - Rearend 2 08-24-2009 08:30 PM
transmission seals price Transmission - Rearend 1 07-11-2008 08:06 PM
chevy 350 blowing water pump gaskits out airwright Engine 11 08-31-2007 08:05 PM
