Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 Transmission Rebuild Tips and Pics.
Old 10-07-2012, 08:46 PM
zardiw zardiw is offline
This is the order you should do this.....or at least the order I'm gonna be doing it, since I'm in the middle of this deal.
1. Use zip lock sandwich bags to keep your parts in. Label the less obvious ones with a sharpie.
2. Take PICTURES as you're doing this job. LOTS of them.
3. Take out each main assembly, like the pump, the clutch packs/assemblies, until you get them All out....and you have an empty case. i.e. don't get sidetracked taking stuff apart until you need to.
4. Then work your way back wards starting with that reverse clutch etc.
Anybody got a pic of that air passage you gotta blow in to get the reverse piston out?......lol
z
