This is the order you should do this.....or at least the order I'm gonna be doing it, since I'm in the middle of this deal.
1. Use zip lock sandwich bags to keep your parts in. Label the less obvious ones with a sharpie. 2. Take PICTURES as you're doing this job. LOTS of them. 3. Take out each main assembly, like the pump, the clutch packs/assemblies, until you get them All out....and you have an empty case. i.e. don't get sidetracked taking stuff apart until you need to. 4. Then work your way back wards starting with that reverse clutch etc. Anybody got a pic of that air passage you gotta blow in to get the reverse piston out?......lol z Last edited by zardiw; 10-07-2012 at 09:13 PM. |
Valve Body Pins/Pistons
These pins were a royal pain. The ones in the blind holes anyway. They ARE just dropped in there, and will come out with a little effort.
Play around with pushing the front of those valves and at the same time banging the valve body on a piece of wood to try to get them to drop out. If they come out enough for you to grab them with a pair of little forceps, you are good to go.......Also pay close attention which valves go in which holes. They should have some marks on the front.....if not I suggest you make some. And put them in baggies after you get them out too.....And MARK the baggies with your sharpie. I had one valve body that was HARD to get out....it was the 3rd one from the left....(with the channels up). I used a little screw driver that was bent on the end to CAREFULLY push on the piston through the channels. Once it was out enough to expose a lip, it was a lot easier to get it out......There was a burr where the pin was and that what caused it to be so tight......z Last edited by zardiw; 10-07-2012 at 09:12 PM. |
Gasket removal tip
Go buy yourself a scalpel with a box of #11 blades. This is an awesome tool anyway, but it's just the thing to scrape off the gasket if it's a ROYAL PAIN like mine was. Made by TransTec.....make a note. Most of it came out, but there were LOTS of places where it was almost welded to the channels.
When you use this, use 2 hands so you have lots of control. Cause you really don't wanna screw up those channels......it's ALUMINUM..lol...and that scalpel blade is Surgical STEEL....... Also, scrape that blade on a flat piece of the bottom BACKWARDS every once in awhile.....to kind of dull it a little bit.......and flip it over and use the other side too.....It's surgical steel, but it will get some burrs from use.......so you can scrape it backwards on a wide flat piece (like where the pan sits) to get those gone..........sounds a lot more complicated explaining it than it is once you get going.........z Last edited by zardiw; 10-07-2012 at 09:11 PM. |
Making the bottom channel area Flat.
You know those T squares with the Sliding deal with a bubble in it and a thumb screw.....Well, that bar is about 1/8" thick and STRAIGHT.......and sharp.....So I had a high spot on those channels......and I just scraped that bar across it and shaved off a little aluminum......and actually made it pretty straight.....lol........z
I know I'm gonna catch some flack for that one........LMAO........z |
Rear oil port for removing reverse clutch
It's at the very back towards the rear on the bottom where all the channels are. It's one of 2 far as I can tell.....I'll try it tomorrow and post a pic where it is. You blow air in there to force that piston out.....z
Some pics. TH350 Rebuild pictures
Shows the output shaft little snap ring, and details about getting that ring to rotate by bending the anti clunk spring.
![]() ![]() ![]() z Last edited by zardiw; 10-07-2012 at 10:53 PM. |
| 200-4R Transmission Rebuild Tips Needed | mustangstomper | Transmission - Rearend | 3 | 05-06-2012 05:21 PM |
| i could use some quadrajet rebuild tips | jak327 | Engine | 9 | 11-17-2010 02:04 PM |
| Powerglide Build tips with pics? | pittbull7934 | Transmission - Rearend | 3 | 10-17-2009 07:05 PM |
| Tips on C-4 Rebuild | Arrowhead | Transmission - Rearend | 6 | 06-18-2008 09:14 AM |
| c-4 trans rebuild tips | FAIRLANE DUDE | Transmission - Rearend | 1 | 07-01-2003 04:43 PM |
