Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 trouble
Thread: T-350 trouble
Old 11-05-2012, 11:23 AM
rick 427's Avatar
rick 427 rick 427 is offline
Last journal entry: 33 WILLYS
Your filter is clogging up,causing it to quit moving....when you shut it off,the particles leave the filter[screen],and float in the fluid...and when you re-start,the stuff gets sucked back into the filter again,causing it to quit moving again after a bit of driving. You could try, but changing the filter is usually not the fix,as they shouldn't clog in the first place,unless something in the trans is failing.My bet is that if you pulled the pan,you will find fine metal thru out the pan and filter from something inside the trans or converter failing.
