Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - t-350 troubles
Thread: t-350 troubles
Old 05-01-2011, 06:54 PM
papamikey papamikey is offline
shifting problem
Originally Posted by gab
i installed an edelbrock 1405 w/ electric choke on a 2101 performer manifold in my sons 84 chevy truck (305)
runs great however the trans doesnt shift unless done manually on a soft take off. at wot it will shift.
it was fine before. vacuum is hooked up to manifold and kickdown cable is attached. i have tried to set the kickdown cable and it has made no difference in this soft take off. we also took off all emissions and ac that wasnt used. there is an electtrical connection on trans near the speedo cable this is not hooked up? should it be? and to where?
any help would be apprecited thx
kickdown cable is only for passing gear. vacuum modulator needs manifold vacuum. check with vacuum gauge. also has governor that could have stripped drive gear
