T-350: type of cooler line material to use.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2012, 06:55 PM
New ques re: th350 cooling lines. I am somewhat confused on why type of lines to use. Braided are nice but espensive. Coated steel are good but very difficult to bend without a good tubing bender. I would to settle on 5/16 copper, with single flares, because it is affordable and a decent size to bend. Also need to introduce a short piece of hose, veritcally in both lines near the radiator, to absorb engine vibration. So the ques: I hear that copper is not a good metal to use for the application. Maybe it reacts to hydraulic fluid, I don't know. Can't be pressure problem cuz I believe the press is about 8 lbs. Your thoughts...Ed
Old 11-29-2012, 08:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The cooler line pressure is considerably higher than 8 psi, can be upwards of 50 psi or more, depending on the mods done and the main line pressure.
I really do not see a problem w/using copper if the tubing is good quality and has good support that keeps it from work hardening and cracking. But steel is cheaper and somewhat tougher, even though it's a little harder to flare and is harder to bend.
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
tenfords:
I moved your new question on cooler lines to a new thread.
When you add a new question to another member's thread, your new question is lost.
T-350 cooler line fittings and size? tenfords Transmission - Rearend 6 11-25-2012 02:11 PM
TH 350 cooler line oil flow jeepers creepers Transmission - Rearend 5 09-28-2012 12:41 AM
Clutch Disc Material and Pressure Plate Type Argess Transmission - Rearend 11 09-28-2010 07:18 AM
1940 Ford Sedan Interior - Material Type/Quantity iceman_1000000 Interior 2 05-26-2010 12:16 AM
FUEL LINE & TRANS LINE SIZE/TYPE leejoy Hotrodding Basics 7 11-29-2005 10:59 PM
