T-350 valve body - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2012, 03:19 PM
T-350 valve body
just took apart my turbo 350 transbrake valve body and it has no gaskets? This is a race built transmission, did someone forget to put gaskets in or is supposed to be like this?
Old 10-19-2012, 06:20 PM
Crosley's Avatar
Wiki Edits: 1659
Many race trans v-bodys do not use gaskets. Usually the separator plate is aluminum
Old 10-19-2012, 06:37 PM
thanks for your reply!
Old 10-19-2012, 06:42 PM
Crosley's Avatar
Wiki Edits: 1659
yeh, you were gettin nothing at Yellow Bullet
TH 350 Reverse Manual Valve-body Questions qsharp84 Transmission - Rearend 2 11-27-2011 04:00 AM
New 350 valve body vs 350 Valve body reprogramming kit terminator0723 Transmission - Rearend 4 04-14-2009 07:41 PM
th-350 valve body exploded diagram needed jeffvega Transmission - Rearend 1 03-02-2009 12:42 AM
T-350 7 400 valve body problems? bigiron40 Transmission - Rearend 2 05-10-2008 07:23 AM
C4 valve body mhaener Transmission - Rearend 0 12-26-2002 11:01 AM
